1 members (Otto Skorzeny), 115 guests, and 0 robots.
Topics128,049
Posts1,055,549
Members48,425
#646395 05/14/2010 11:57 AM
I'll check into my advance a little more but I'm thinking my '62 235 is in need of a new/working one. Are there any good sources for these? Retail chains and LMC don't have them. thanks
1962 C-10 Chevy
More pix on Photobucket
ADHD and luvin' it
Jim Carter and a few others sell them. New,, about $40
Used, about $15. They are on EBay alot too. I don't think it's a must to be year specific, but I don't know what year span to tell you. Others here probably can.
Drew
Thanks.
My 62 has the advance low on the dist. shaft and are not a very popular item to reproduce. I'll know more about what's wrong with it when I break everything down and clean it up. I know I'll dwell on it while I'm doing the body if I don't fix it now......yep, I'm nuts.
1962 C-10 Chevy
ADHD and luvin' it
Thanks!
1962 C-10 Chevy
ADHD and luvin' it
I just purchased two from my local parts supplier...East Side Auto Parts (Advance Auto Parts) for $16.95 + tax. I bought one to install and the other as a spare. Most auto supply stores have them.
Every vacuum advance unit that I have ever seen on a 235 kinda' wiggles back and forth when you rev the engine. I would think a nice, smooth, fluid motion would be ideal, but maybe not on these old engines...Is it supposed to be this way, or has every 235 I've ever seen had a vacuum leak? Opinions welcome. Jim
depends on just what ya mean Chet, when you momentarily 'goose' it, the vacuum advance moves the distributor, when you hold a steady higher RPM it stops moving, the advance has to do with acceleration not steady speed - no "nice, smooth, fluid" changes in vacuum when you "rev it"
