1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | I'll check into my advance a little more but I'm thinking my '62 235 is in need of a new/working one. Are there any good sources for these? Retail chains and LMC don't have them. thanks | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Jim Carter and a few others sell them. New,, about $40 Used, about $15. They are on EBay alot too. I don't think it's a must to be year specific, but I don't know what year span to tell you. Others here probably can.
Drew
| | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | Thanks.
My 62 has the advance low on the dist. shaft and are not a very popular item to reproduce. I'll know more about what's wrong with it when I break everything down and clean it up. I know I'll dwell on it while I'm doing the body if I don't fix it now......yep, I'm nuts. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I just purchased two from my local parts supplier...East Side Auto Parts (Advance Auto Parts) for $16.95 + tax. I bought one to install and the other as a spare. Most auto supply stores have them. | | | | | Joined: Aug 2008 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 116 | Every vacuum advance unit that I have ever seen on a 235 kinda' wiggles back and forth when you rev the engine. I would think a nice, smooth, fluid motion would be ideal, but maybe not on these old engines...Is it supposed to be this way, or has every 235 I've ever seen had a vacuum leak? Opinions welcome. Jim | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | depends on just what ya mean Chet, when you momentarily 'goose' it, the vacuum advance moves the distributor, when you hold a steady higher RPM it stops moving, the advance has to do with acceleration not steady speed - no "nice, smooth, fluid" changes in vacuum when you "rev it"
Bill | | |
