3 members (Nick in Manitou, Otto Skorzeny, dt235sd), 226 guests, and 10 robots.
Topics128,077
Posts1,056,032
Members48,433
#646587 05/15/2010 2:08 AM
Do I need to torque the head bolts, had a complete overhaul. Getting ready to drive it for the first time. It is a 54, 235. Thanks
It depends on the head gasket design. The conventional wisdom way back when these engines were new was to warm the engine up to normal operating temperature, do a hot retorque on the head bolts, and readjust the valves hot. Some of the newer head gaskets claim to be "no-retorque" types, but since the head bolts on a stovebolt 6 are so easy to reach, I'll usually do a hot retorque anyway.
Now come on Jerry, tell us again how you get to that one head bolt betwix 3&4 with out pulling the rocker assembly off?????
Denny Graham
Sanwdwich, IL
Denny G
Sandwich, IL
