| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 18 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 18 | Do I need to torque the head bolts, had a complete overhaul. Getting ready to drive it for the first time. It is a 54, 235. Thanks | | | | | Joined: Feb 2004 Posts: 29,802 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,802 | It depends on the head gasket design. The conventional wisdom way back when these engines were new was to warm the engine up to normal operating temperature, do a hot retorque on the head bolts, and readjust the valves hot. Some of the newer head gaskets claim to be "no-retorque" types, but since the head bolts on a stovebolt 6 are so easy to reach, I'll usually do a hot retorque anyway. Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Now come on Jerry, tell us again how you get to that one head bolt betwix 3&4 with out pulling the rocker assembly off????? Denny Graham Sanwdwich, IL
Denny G Sandwich, IL
