7 members (TexasFarmTruck, Otto Skorzeny, MOTOXFAMILY, Phak1, kurbside bolter, 2 invisible), 157 guests, and 3 robots.
Topics128,268
Posts1,058,378
Members48,485
#646242 05/14/2010 12:27 AM
U
U Offline
Trying to figure out why my gas gauge does not work. All the gauges in the speedo display has been rebuilt. The wires, sending unit, and tank are new. When I turn the key could I test the brown wire to the tank with a test light? I did this and there seemed to be no power. The gauge worked before the restoration.
Thanks!
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
UnklRod #646264 05/14/2010 1:13 AM
the wire to the tank is a ground, variable as the float moves, the power comes from the ignition sw when it's turned on, with a test light you'd go from the + pin on the gauge to ground [dash] - if you've got an ohmeter, check continuity of the brown wire from the gauge to the sender [key off] ... there's a connector under the floor that could have gotten unplugged
squeeze #646265 05/14/2010 1:15 AM
Disconnect the lead to the sender on the back of the gauge, Turn on the key. If the gauge pegs to Full, you have a good gauge and good gauge ground; otherwise, the problem is in the lead to the sender, the ground at the sender, or the sender itself.
tclederman #646270 05/14/2010 1:18 AM
U
U Offline
OK, So the brown goes under truck and back in to the cab under the tank to the sender unit. There is a white wire coming from the sender down to the floor. Is that the ground for the sender?
Thank you guys!
More pix
UnklRod #646276 05/14/2010 1:26 AM
if that white wire is from a mounting screw in addition to the brown one to the sender terminal, then it'd likely be a ground - not original tho
squeeze #646323 05/14/2010 4:09 AM
U
U Offline
Hi Bill,
I was looking at the manual for my truck and there is a white ground wire from the tank sender to the cab floor. SECT. 12 SHEET 26.
More pix
UnklRod #646340 05/14/2010 4:55 AM
so ya should have a good ground - I've never seen a seperate ground wire on'em, and the straps bolted to the floor are so tight I wouldn't expect a problem without it
check the continuity of that brown wire, or as Tim said, remove it, or short it to ground and see if the gauge moves as you do so
squeeze #646627 05/15/2010 4:20 AM
U
U Offline
Hey Tim & Bill,
Got the gas gauge to work. It was just that white ground wire that was not working.
Now to figure out the oil pressure and temp gauges!
Thanks!
Jon
More pix
squeeze #649346 05/24/2010 10:33 PM
how can i get to the gauges in bezel i can pull it out but the speedo plug holds in from coming out, does it just pull out twist off clamp ..... Also waht is this wire thats on floorboard that could have come on done squeeze that u speak of?
mejia11 #649349 05/24/2010 10:37 PM
Jon,
Good job.
The other gauges are usually easier to set-up (or diagnose) compared to the fuel gauge.
