| | | Forums66 Topics128,143 Posts1,056,786 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | Hey guyz, Great site! I just bought a 53 3100 for $800. I have a 450 hp small block chevy on a stand waiting to go in. I have my old car from high school (84 monte carlo ss) sitting waiting to get parted out or sold as a roller. I have several questions here. First the car has a 8.5 10 bolt out of a GN I built with 4.10s and a new eaton posi. I can sell this rearend for good money and put a 150 dollar junkyard rear under the truck or should I keep the Gn. I would like to put a 6 speed in the truck for highway use an still have the low gears for playing. Will a 6 speed out of a late model vette or 97-03 Z28 fit? Also I plan on trying to put the truck on air ride, Which suspension is the best bang for the buck for the front end. Any opinions or input would be greatly appreciated. Thanks Aaron | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The 'vette transmissions are hard to adapt, I'd suggest looking for something from a Camaro or Firebird instead. The earliest 'vette 6-speeds do not have a conventional rear mount and the later ones are transaxles.
Measure the width of your GN rear. If it is stock width for the Monte it will be narrow enough you'll need wheel spacers or will need to tub the truck to use it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | What rearend has the best fit on the truck. how big of spacers would I need, how will this effect the truck? I have never ran spacers. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The standard Monte rear is narrow enough that a wheel that covered the backing plate is likely to allow the tire to touch the bed. However, you really need to choose your tires and think through how they will fit in the wheel wells before choosing wheels, and only then would you be able to decide how much spacer it would really take.
I am not a fan of spacers because of the way they add leverage working against the bearings. I'd work to figure out the ideal width of the rear before using spacers.
I don't recall the width of the Monte rear but it is pretty narrow. I have a '73 Chevelle rear under my Suburban, which is about 62 inches wide. That is close to the stock measure and works real well under my truck. The Monte is closer to 58 or 56 inches and with most wheels is going to crowd the inner fender.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | A junk yard rear shouldn't cost more than $50, and you can find any ratio you want. | | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | I would like to fit wide tires on big wheels with good tuck for the the air ride. I wonder what width rear would work the best. I dont think I would want spacers If I didnt have to go that rout. | | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | What do you guys think about a ford explorer rearend. 8.8 you can get them with 373s, posi and with disc brakes on 95 and up. suppose to be 59.5" wide. I could get the mustang II in the 4.5" bolt pattern to match the explorer rear. | | | | | Joined: Mar 2009 Posts: 58 New Guy | | New Guy Joined: Mar 2009 Posts: 58 | What I used on my '53 and am using on my '54 is a rear end from a '70 Ford F100. It's 61 3/4" from brake drum mounting surface to the other side. I have a 3.5 gear ratio with positraction or whatever Ford calls it. Anyway, a good place to have your differential gone through is Randy's Ring & Pinion in Everett, Washington. The do work internationally and have one humoungous facility. So you know what happens beyond this is I'm using 17" wheels with a 4 1/2 inch backspace from Billet Specialties. It leaves me with about 3/4" clearance between the tire and bed sides. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The 8.8 is considered a good rear. If you start with something that narrow you may be limiting your wheel choices unless you tub the bed. Until you decide on wheels and tires making an axle choice may be premature.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2009 Posts: 58 New Guy | | New Guy Joined: Mar 2009 Posts: 58 | I'm in the mood to think about how I am going to redirect cables and wires so as not to run them through the firewall. I want to keep the firewall clean on my '54 truck. One thing I will do is not install the front fenders & inner fenders which will remove the temptation of mounting on those surfaces. Anyone know of sites that suggests hardware for channeling wires through the lower firewall or frame area? | | | | | Joined: Mar 2009 Posts: 58 New Guy | | New Guy Joined: Mar 2009 Posts: 58 | Sorry, I accidently published the above topic as a "Reply" in this section and not as a new topic. Too many Tecate's.......... | | | | | Joined: Mar 2009 Posts: 58 New Guy | | New Guy Joined: Mar 2009 Posts: 58 | Sorry about the above posting. I posted it as a "Reply" rather than a "New Topic". Hopefully the moderator will delete it as it has been reposted as a "New Topic". | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I am, fortunate to live fairly close to the Summit Speed Shop.They carry many wheels with just about any backspacing you need. Ya might wanna get one of their catalogs and order what you need.Just a sugestion. | | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | I think I am going to go with the explorer 8.8. I guess I will find out how it works and post it. What is some of the better price venders for these trucks. Thanks
Aaron | | |
