| | | Forums66 Topics128,022 Posts1,055,361 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64629 08/21/2006 6:03 AM | Joined: Jul 2006 Posts: 149 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 149 | Ok here goes...... I've just captured another big bolt... a '48 2-ton Boom truck, from the 2nd owner. It seems the prior to his ownership, someone swapped engines.... so now? it has what appears to be a late (full pressure) 235. The only info on this engine is the numbers on the pad next to the distributor. Here are the number I found... 95T2982F255N as best as I can see anyway... I had to scrape alot of dirt off the pad.... and wasn't in the best position to read ##'s..lol Anyone have any ideas as to the indentity of the engine?? Michael \'48 chev 2-ton boom truck (Boomer) '49 Chev 2-ton flat bed '65 Chev 35ft school bus '88 GMC 6500 '72 Superior 26ft class "A" coach '50 Farmall "M" '71 MGB GT '68 Austin-Healey Sprite '65 Austin-Healey Sprite and various other odd British cars and lots of old radios..... Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
#64630 08/22/2006 1:38 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 1955, second series, made at the Flint plant. Cant find thr original application in my book, possibly 1 1/2 ton or larger.
Bill Burmeister | | |
#64631 08/22/2006 5:38 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | For 1955 the Chev parts book shows the N suffix as being a 261.
See the USA in your vintage Chevrolet! My Blog | | |
#64632 08/23/2006 1:12 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's why I couldn't find it, my book only covers 1/2 through 1 ton. But it does give the year and plant codes.
#64633 08/23/2006 4:28 AM | Joined: Jul 2006 Posts: 149 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 149 | thanx...now I need to look for the spec's on a '55 261...... lol Michael \'48 chev 2-ton boom truck (Boomer) '49 Chev 2-ton flat bed '65 Chev 35ft school bus '88 GMC 6500 '72 Superior 26ft class "A" coach '50 Farmall "M" '71 MGB GT '68 Austin-Healey Sprite '65 Austin-Healey Sprite and various other odd British cars and lots of old radios..... Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
#64634 08/23/2006 12:23 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | 235 will have a 4 bolt VC,,water pump high on the block,,,261 will have captons bars above the starter and water pump lower on the block...doc | | |
#64635 08/23/2006 3:09 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Only a 1954-55 first series 261 will have the high mount water pump.
