5 members (Hotrod Lincoln, baldeagle, Otto Skorzeny, TooMany2count, Shardean), 125 guests, and 3 robots.
Topics128,024
Posts1,055,392
Members48,422
#64629 08/21/2006 6:03 AM
Ok here goes......
I've just captured another big bolt... a '48 2-ton Boom truck, from the 2nd owner.
It seems the prior to his ownership, someone swapped engines.... so now? it has what appears to be a late (full pressure) 235.
The only info on this engine is the numbers on the pad next to the distributor.
Here are the number I found... 95T2982F255N as best as I can see anyway... I had to scrape alot of dirt off the pad.... and wasn't in the best position to read ##'s..lol
Anyone have any ideas as to the indentity of the engine??
Michael
\'48 chev 2-ton boom truck (Boomer)
'49 Chev 2-ton flat bed
'65 Chev 35ft school bus
'88 GMC 6500
'72 Superior 26ft class "A" coach
'50 Farmall "M"
'71 MGB GT
'68 Austin-Healey Sprite
'65 Austin-Healey Sprite
and various other odd British cars
and lots of old radios.....
Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
#64630 08/22/2006 1:38 AM
1955, second series, made at the Flint plant.
Cant find thr original application in my book, possibly 1 1/2 ton or larger.
Bill Burmeister
#64631 08/22/2006 5:38 AM
For 1955 the Chev parts book shows the N suffix as being a 261.
My Blog
#64632 08/23/2006 1:12 AM
That's why I couldn't find it, my book only covers 1/2 through 1 ton. But it does give the year and plant codes.
Bill Burmeister
#64633 08/23/2006 4:28 AM
thanx...now I need to look for the spec's on a '55 261...... lol
Michael
'88 GMC 6500
'50 Farmall "M"
'71 MGB GT
#64634 08/23/2006 12:23 PM
235 will have a 4 bolt VC,,water pump high on the block,,,261 will have captons bars above the starter and water pump lower on the block...doc
#64635 08/23/2006 3:09 PM
Only a 1954-55 first series 261 will have the high mount water pump.
My Blog
