| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | i have a 49 chevy 6400 and i need to replace the bearing where the driveshaft goes into the 2 speed rear end.im guessing you call it the the fron pinion?i took the driveshaft off, and i got the big nut and washer off, but the deadblow hammer and a piece of wood doesnt seem enough.any other ideas? Thanks Dan | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | A larger BFH, the kind usually found near a ford project.
Seriously, try soaking it for awhile and getting a puller to help things along. Now maybe someone who does this frequently has a better idea and will provide it. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Feb 2004 Posts: 29,844 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,844 | Hammering on the yoke will guarantee you'll need to replace the rear pinion bearing. It Brinnels the bearing race, and you'll have a noise, and very rapid pinion bearing wear. Use a 2-jaw puller with the jackscrew pushing against the center of the pinion gear, where you just removed the nut. You'll be able to replace the front bearing cone, but not the cup, and replace the grease seal. Any further disassembly will require either removing the pinion carrier if there's a ring of bolts holding it into the main carrier housing, or removing the whole center section if the pinion does not have its own housing. Be sure to save the gasket and whatever shims are behind the pinion carrier- - - -that's how the pinion gear depth is set on some rear ends. Jerry
| | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | hey again, i got the yoke off finally after a good beating with the deadblow and some wood.i got the front seal off but i munched the rear seal while doing so.i took off the whole pinion carrier to pop out the inner seal from the other side but it seems as if the pinion is pressed in there?any ideas of getting that pinion out of the carrier? Do i have to replace the bearings as well?when i took off the carrier, there were only shims, no gasket.Is this normal? I saved the shims. Dan | | | | | Joined: Feb 2004 Posts: 29,844 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,844 | Yes, the shims act as a gasket on some applications. Just use a little brush-on Permatex sealer to prevent seepage between the shims as you reassemble it. Sometimes the front bearing cone is a TIGHT slip fit on the pinion gear, so a press is a good idea unless you want to risk damaging the bearings with more hammering. You'll probably find the rear bearing cone is a tight press fit onto the pinion gear. The bearing cups will be pressed into the housing you just removed. Once you've got the pinion out of the housing, wash and inspect the bearing cones and cups. If they don't have score marks or flat spots, you can probably reassemble the unit with just a new seal. Why did you take it apart in the first place- - - -noise, or just leakage?
There's a process called "preloading" the bearings, where you tighten the yoke nut until there's a specified amount of drag as the pinion turns in the housing- - - -measured in inch-pounds, so don't overtighten the nut! If you can find a factory service manual, most of them show a pretty good step-by-step procedure for disassembly, inspection, and reassembly. Jerry
| | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | i took it apart because i had major leakage/spray while driving.i just need to get the pinion pressed out of the cage so i can replace the seals, inspect the bearings and then press the whole mess back together. Dan | | |
