7 members (Hotrod Lincoln, Oldcaliforniakid, 49nut, frogfarmer, Stovebolt48, mason86, Woodcmiami), 89 guests, and 1 robot.
Topics128,050
Posts1,055,671
#645791 05/12/2010 4:56 PM
I picked up an oil filter canister that is susposed to fit the intake manifold, or so I think, but this one is too wide to fit the raised bosses on the manifold, its on an early 235 babbit, does anyone have a picture of one on a manifold.
my 59-235 had the filter housing mounted to the intake. it was held in place with a muffler clamp. only the threaded rod portion was used and the nuts were on the inside of the filter mount with the threaded rod going through the bolt holes. it was mounted on the manifold forward of the carb.
Thankyou, I knew that, my problem or so I think it is, it that the clamps onm mine seem to be wider than what it needs to be to clamp there, it actually gets up past where the horn bolts to.
ABento #646055 05/13/2010 11:12 AM
ABento,
How wide are the "clamps" on yours? Can you post photos? There were a wide variety of types and brands of filters and a variety of attachment brackets.
Are you trying to get the bracket (and both mounting u-bolts) to the rear of the horn boss (forward of the carb)?
You'll see from this diagram that the bracket/bolts "straddle" the horn boss (and are positioned as far to the rear as possible). More location-instructions for another assembly.
The one pictured is what I have Tim, measuring outside of the edges of the bracket it is 5 1/2 inches and it puts the holes way out of alingement to the bosses on the manifold and runs just passed a 2 hole boss that the horn bolts to, I'll try to get a decent picture of it today, and doesn't touch the manifold except where the half round portion of the mounting is, it doesn't even come close to resting against the two raised bumps.
Thankyou
ABento
Here are a few pics Of oil filters. Some of the pics I have saved from ebay listings. Others are off my truck. 1950 3100, 235, Manifold is off a 216
oil filter pics
Hope it helps
Mine is like the blue AC filter, I was under the impression that it was between thew hon mounting and the carb, I didn't realize that it went passed it, what is misleading on mine is there are two bumps on the carb side of the horn mount I thought that that was for a rest for the filter bracket to bump against,I didn't see them on your picture, I'll try to get pictures up.
