0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#645016 05/10/2010 7:34 AM
U
U Offline
Is there a special way to install the fender welt on the back fenders of a 57 3100?
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
I tried....and gave up....looks fine without.....My 2Cents....
GMC: Get More Cash...
1958 GMC
My Webshots photos
Jim Carter's catalog indicates that rear fender-welt was not originally used on rear fenders (welting was also not used on Advance-Design rear fenders).
Nonetheless, here is a Tech Article from ClassicTruckShop.com
Some people have reported that they have cut off the bead and use the remaining strip and/or use a strip of heavy roofing paper/sheet (attached the fender with seal-adhesive).
Not sure of flange detail on your '57 fenders. On my '40, I used weatherstrip adhesive to hold the welt flange in place before bolting up to body.
1940 Chevy KC 1/2-Ton
My Rear Fender Welting Job Click Here
I used fender welting on the rear fenders before I read threads on here that none was used on AD trucks from the factory. I cut the welting on angles at the various points where it makes a bend around the fender. I bought a magnet set and a clip set from Harbor Freight for around 15 bucks I think it was. I pre staged the welting and made any trims and cuts to make sure it laid flat on a dry run. I used Super Weather Strip adhesive on the leading edge of the fender and the opposite edge of the welting to create a dual bonding fit. You will have about 4 or 5 minutes to make adjustments to the placement once you start. Do as much work before you start to make it a smooth install as possible. I currently have to get some super weather strip remover to clean up small smudges on the front side of the fender, but all in all I think the look actually came out pretty good considering it never had it originally.
I installed it on both My rear fenders...also My rear fenders
had welting on them when I removed them...Its only common sense to install it as You have a metal fender mounting to a metal box with the potential of water, mud, and debris entering and lying dormant,
causing a rust problem too soon...To install the welting I cut "V"
shaped cuts the entire length of the welting which allows all the bends necessary to install...when installed, the round bead will keep the debris away from the problem area. Bill B.
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
Bill_B #645922 05/13/2010 12:16 AM
U
U Offline
Hi Bill,
I hear that is the way to go. How large of a V would you cut out for the bolts?
Jon
More pix
Here is a photo of the V-cuts shown at the link I posted above.
U
U Offline
tc,
Great work...do I really have to use the adhesive? I just got the truck back from the paint shop and they left the rear fenders loose and I really dont want to take the fenders off. Can I just cut the V's in the welt and install?
More pix
yes you can skip the glue John, only useful to tack the welt on the fender before assembly
U
U Offline
Sweet!
More pix
U
U Offline
Got the welt in. It was very easy...ugly cutting job but heck I will not see it. I left fenders loose in order to get the stepsides on. then will tighten down the fender bolts.
Thank you for the help!
More pix
U
U Offline
On a 57 stepside, how far would the welt come down on the rear fender? I was not thinking and cut the welt at the front of the fender right where the seam of the stepside step meets the side panel. I hope that made sense. I will post a photo soon.
More pix
