1 members (RoseB),
109
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 5 New Guy | | New Guy Joined: May 2010 Posts: 5 | I have a 46 1 ton with dual rear wheels. They are 6 lug 16" with 5 1/4 in center hole. The lugs are 7 1/4 center lug hole to cross center lug hole. Iam looking for replacement wheels orig split rim or anything. HELP | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i have the same wheels but sorry i dont have any extras. do you have the timkin split rear on your truck? i was looks for other wheels to fit mine but havent. i dont think there are any options out there except to change out the rear | | | | | Joined: May 2010 Posts: 5 New Guy | | New Guy Joined: May 2010 Posts: 5 | We went salvage yard hopping today. Found out all ford chev dodge gmc 6 lug with 7 1/4 bolt pattern will work you just have to have 6 matching wheels. The ford center hole is 5 1/2 in tho but will still work on the gmc | | | | | Joined: Feb 2009 Posts: 8 New Guy | | New Guy Joined: Feb 2009 Posts: 8 | Hi guys, I have the 41 GMC with 6 lug 7 1/4 pattern , what Ford Chev. Dodge has this pattern? I sure would like to get rid of the split rims. | | | | | Joined: May 2010 Posts: 5 New Guy | | New Guy Joined: May 2010 Posts: 5 | I found them on a 61 1 ton ford they had the lug holes that were in and out that locked into them self, and were one piece wheels. They fit right on my gmc. The wheel is a 17 1/2 in wheel tho, but they do have 16 also
| | | | | Joined: Feb 2009 Posts: 8 New Guy | | New Guy Joined: Feb 2009 Posts: 8 | Thanks for the info. I guess then they will be on 60s trucks or do you think newer? I really wish I could change the front to 8 lug but so far spindle size has been a problem. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Have you looked at the axles instead of the spindles? On 1/2-ton trucks the axle part number is the same '41 through '54. If the 3/4- and 1-ton is also the same across those years it would mean you could swap axles to one with 8-lug axles.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
