| | | Forums66 Topics128,080 Posts1,055,945 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64608 08/20/2006 8:41 PM | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | After reading thruwurkin thread i got to wonder is there a spot on my 1954 3100 rear end that indicates what the gear ratio is. This may help me determine how fast I could drive . Thanks Peter | | |
#64609 08/20/2006 10:24 PM | Joined: Mar 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 63 | Enclosed driveline (torque tube) is a 4.10 If it is a open driveline then usually a 3.90 Good luck, wayne | | |
#64610 08/20/2006 10:52 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | here is an old post that may help old post Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#64611 08/21/2006 12:12 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | The stock closed torque tube in 1954-3100's with 3 or 4 speed transmissions was a 3.90. Use the engine rpm/R&P ratio/speed/tire diameter calculator in this forum to lock in on your exact speed. Life is tough (and shortened) on a 235 that spends much time at 3000 rpm. The 235 makes good torque from 1600 up through 2100 with no strain. Hope this helps. | | |
#64612 08/21/2006 2:26 AM | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | Thanks for all the advice very helpful Peter | | |
#64613 08/21/2006 2:50 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Fla54Chevy3100 is correct. 1954 was the only year to use a 3.9 torque tube diff.
See the USA in your vintage Chevrolet! My Blog | | |
