2 members (Leo, amtrakjoe), 58 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#64608 08/20/2006 8:41 PM
After reading thruwurkin thread i got to wonder is there a spot on my 1954 3100 rear end that indicates what the gear ratio is. This may help me determine how fast I could drive . Thanks Peter
#64609 08/20/2006 10:24 PM
Z
ZB3 Offline
Z Offline
Enclosed driveline (torque tube) is a 4.10
If it is a open driveline then usually a 3.90
Good luck, wayne
#64610 08/20/2006 10:52 PM
here is an old post that may help
old post
Redryder pix
My Hotrod
#64611 08/21/2006 12:12 AM
The stock closed torque tube in 1954-3100's with 3 or 4 speed transmissions was a 3.90. Use the engine rpm/R&P ratio/speed/tire diameter calculator in this forum to lock in on your exact speed. Life is tough (and shortened) on a 235 that spends much time at 3000 rpm. The 235 makes good torque from 1600 up through 2100 with no strain. Hope this helps.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#64612 08/21/2006 2:26 AM
Thanks for all the advice very helpful Peter
#64613 08/21/2006 2:50 AM
Fla54Chevy3100 is correct. 1954 was the only year to use a 3.9 torque tube diff.
My Blog
