0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | I put a new wiring harness on my '54, am concerned about the main power wire from the starter going into the dash. If anything in the dash short-circuits, that main wire is going to burn.
I found a 14ga fuse link at the parts store and want to install it on the end of main power wire that connects to the battery cable at the starter.
I ask: have others done this before? Is it a good thing? Will it cause problems? Am I overly concerned? Don | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | I think a 14 Gauge will be a little small for the load, especially if you're running an alternator. If you're running the charging current through the original dash-mounted ammeter, I'd reccomend a 10 gauge fuse link instead. It will still burn out in case of a major short, but it won't fail in case of a heavy charging surge immediately after starting. I've seen alternators produce spikes of close to 100 amps (full stator capacity) just as the engine starts after cranking for several seconds, particularly in cold-weather starting situations. BTW, you can also increase the capacity by doubling up on the 14 gauge links, running two of them in parallel to each other. Jerry
| | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | Thanks Jerry,
I've got the original 6v system with generator. The harness has a 10 ga to the battery hot connection. Two web site are telling me to use a 14 ga fuse link. I think I'll go with that and see how well it works out. Don | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | Jim, Jerry,
Thanks for the help. I'm working on finishing the install of new original style wire harness. Think this is the best time to encorporate additional fuses/fuse links, still not sure what I will do. Do yoy know anything about the thermal breaker on the headlight switch. Now working on the turn signal circuts. Don | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | The thermal breaker is there to prevent total loss of lighting in case of a short. The breaker will disconnect, stay off a few seconds, cool down, and flash on again, repeatedly, avoiding complete loss of the headlights until you find a place to pull over safely and diagnose the problem. A fuse or a fuse link would just cut the lights off completely at the first sign of an overload. Jerry
| | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | that's good, I've never read anything about it. Don | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | Thanks Tim, hope I'm never in that particular situation but it's good to know.
Just finished the turn signal wiring. Wow, thought it was going to be terrible. I started on the simplest part and worked throught to the last connection. Connected the battery and it all works great. Don | | |
