| | | Forums66 Topics128,092 Posts1,056,040 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | I am in the middle of taking parts off my old engine and putting on the newer rebuilt one--. Doesn't seem to be any threads on the old crank pully shaft. I see directions on how to pull the hamrmonic ballancer but how does the pully itself stay put--rather how do I get the old one off ?----it has the manual start crank ears on this one and that's all I see.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | Thankyou Don--So is it neccessary to take the harmonic balancer off or just pull the whole mass at once? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You should have two threaded holes in the balancer. Use a generic puller, thread the bolts into the two holes, place a 9/16 socket on the end of the crank (the hole between the hand crank lugs, the lugs are part of the balancer) to push against. It'll come right off. Use a BFH to reinstall.
| | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | Thanks for that Tiny--it came off surprisingly easy and heated and used a copper BFh to reinstall. | | |
