0 members (), 119 guests, and 1 robot.
Topics128,105
Posts1,056,541
Members48,448
#643823 05/05/2010 10:14 PM
I can’t seem to stop my aftermarket cartridge type oil filter from leaking around the top seal. I’ve tried 4 times now with varying degrees of no luck. I have checked both the top and the top of the canister for burrs and uneven edges. I’ve tried both rubber and fiber gasket material; I’ve tried varying degrees of tightness. I’m also careful when placing the top on the canister so that it goes on square and does not spin as the bolt is tightened. Any Ideas???
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Kip's41 #643837 05/05/2010 11:16 PM
Riding in the Passing Lane
You probably have an old gasket packed up in the groove. The gasket is very narrow & gets packed up in there. Take an ice pick & poke up in the groove. Dig out the old gasket & put in the new one.
1972 Chevy c10 Cheyenne Super
Thanks for the suggestion but the filter that I have does not have a grove in the cap. It is just a 1/4" wide flat. I have made several different gaskets but have had no luck. The top of the canister is about 1/16" thick and provides very little surface to seal to the gasket. If I over tighten the top it tends to cut through the gasket
Try putting the lid on without a gasket and see if the nut goes down far enough to clamp the lid from turning.
Well......Now, that is a very practical suggestion. I'll try that when I replace the filter at the first oil change.
I need to get a couple hundred miles on the brand new rebuild before its first oil change, just as soon as it quits raining.
Kip,
After following retired wrench's excellent suggestion, if the lid seems to clamp properly, you might have a warped lid and or a non-level mating-surface on the top of the canister. These could be tested by removing the lid, putting chalk on the rim of the canister, and tightening the lid. Remove the lid and see if you have a continuous "bead" of chalk on the mating area?
Thanks for all the help fellas. After checking through all the suggestions I finally ended up cuting a gasket out of thicker gasket paper material and it seems to be wotking just fine
