| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | I picked up an oil filter canister that is susposed to fit the intake manifold, or so I think, but this one is too wide to fit the raised bosses on the manifold, its on an early 235 babbit, does anyone have a picture of one on a manifold. Thanks | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | my 59-235 had the filter housing mounted to the intake. it was held in place with a muffler clamp. only the threaded rod portion was used and the nuts were on the inside of the filter mount with the threaded rod going through the bolt holes. it was mounted on the manifold forward of the carb. | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | Thankyou, I knew that, my problem or so I think it is, it that the clamps onm mine seem to be wider than what it needs to be to clamp there, it actually gets up past where the horn bolts to. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | ABento, How wide are the "clamps" on yours? Can you post photos? There were a wide variety of types and brands of filters and a variety of attachment brackets. Are you trying to get the bracket (and both mounting u-bolts) to the rear of the horn boss (forward of the carb)? You'll see from this diagram that the bracket/bolts "straddle" the horn boss (and are positioned as far to the rear as possible). More location-instructions for another assembly. | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | The one pictured is what I have Tim, measuring outside of the edges of the bracket it is 5 1/2 inches and it puts the holes way out of alingement to the bosses on the manifold and runs just passed a 2 hole boss that the horn bolts to, I'll try to get a decent picture of it today, and doesn't touch the manifold except where the half round portion of the mounting is, it doesn't even come close to resting against the two raised bumps.
Thankyou | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | ABento Here are a few pics Of oil filters. Some of the pics I have saved from ebay listings. Others are off my truck. 1950 3100, 235, Manifold is off a 216 oil filter pics Hope it helps | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | Mine is like the blue AC filter, I was under the impression that it was between thew hon mounting and the carb, I didn't realize that it went passed it, what is misleading on mine is there are two bumps on the carb side of the horn mount I thought that that was for a rest for the filter bracket to bump against,I didn't see them on your picture, I'll try to get pictures up. | | |
