1 members (Materman), 115 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#645777 05/12/2010 4:16 PM
Hmmm. I've been running this 12 volt generator for a good 5 yrs. with same V.Reg. and nothing changed...other than it's toast! Replaced it and am getting the old one re-built as a backup.
OK, what happened? I'm clueless.
Most likely, the cutout relay points in the regulator stuck the last time you turned the engine off, allowing the battery to discharge itself through the generator armature. This usually trashes both the generator and the regulator, and often melts the wiring, or at least the insulation, all the way from the battery cable connection at the starter, through the internal wiring harness to the ammeter, and from there to the regulator and to the armature terminal of the generator! If that didn't happen, consider yourself lucky! I've seen entire vehicles go up in smoke from a stuck cutout relay!
Be sure to change the regulator and inspect all the wire harness connections before putting your truck back in service!
Yes sir I will do that.
I did replace the V.Reg. just for drill.
Thanks, appreciate the reply.
All is well. The garage finally warmed up enough to replace the starter and it did not smoke!!! I've got to say that I like the sound of an 12 volt starter winding up smile Thanks for the help boys.
