1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | I've converted my electrical system to 12 volt in my 53 chevy. How many ohm resistance do I need to put in series with the original 6 volt gas gauge? Seems like I remember seeing this in a previous post, but can't find it now. Thanks in advance for your help. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Ever since I've used Runtz resistors on 6v gauges I've had zero problems. It is an electronic unit that maintains a steady 6v, unlike the old ceramic pot type that let the voltage rise and fall as the charge rate varied. For twenty bucks the correct resistance is all worked out for you.
Evan
| | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | Thanks coilover, how do I get ahold of a Runtz resistor and how will I know which one is right for me? | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Funton, 1955 GMC 8 Cylinder pickups used a 30ohm wirewound resistor mounted on the back of the gauge to drop 12v to 6v for the gauge. The information listed in the parts book is: 7.5120 Unit, Resistance 1516846 10-50 all, 65 all incl. bracket*Fuel & Temp Gauge*12 Volt Six cylinder GMC pickups that year were still 6 volt. 5watt 30ohm wirewound
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | OlBlue, thanks for responding but is the 55 GMC gauge the same as the 53 chevy in terms of its internal resistance? It seems like they would need to be the same for the 30 ohm resistor to work in the chevy. Also it seems to me that if the resistor is mounted behind the gauge it could be hooked in parallel. That would make the resistor act like a shunt. I thank you again for your info but I'm at a loss as to which way to go. | | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | OlBlue , it seems to me that I need to know if the gas gauge is in reality a voltmeter or an ammeter. Knowing this I might be able to wire it. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The resistor, if you use one should be 30 ohms. It goes in series with the supply to the gas gauge. If you are just picking up a resistor from an electronics store then it should be 30 ohms with a 2 watt rating. In rough figures, the power used by the resistor would be V/R x V or 6/30 x 6 = 36/30 or 1.2 watts.
| | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | OlBlue in asking you these questions , I think I figured it out . The gauge is acting like an ammeter. Therefore the resistor should be hooked in parallel. Would someone thats added a resistor to a 53 chevy please respond. Please give all details, thanks. | | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | truckernix, since I see by your bio-- your an elec eng. and the resistor should be in series does that mean that the gas gauge is a voltmeter??? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The gauge works like an ohmmeter. When there is 30 ohms resistance on the sender it reads empty. When there is 0 ohms it reads full.
Last edited by cletis; 05/11/2010 2:13 AM. Reason: Whoops, I meant to say ohmmeter.
| | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | Ok cletis ,if it is an ammeter then I should hook the resistor in parallel right? | | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | Cletis if the gauge is an ammeter then shouldn't I hook up the resistor in Parallel with the gauge???? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I meant to say ohmmeter. I'm not sure how to hook up the resister. I'd recommend the Runtz and follow the instructions. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | The resistor goes in the line (in series) with the voltage feed to the guage. It's purpose is to drop the input voltage to the guage from 12 volts down to 6 volts. The guage itself has 2 coils inside that work in opposition to one another. The "limiting" coil pulls the guage towards empty, and the "operating" coil pulls the guage towards full. 6 volts enters the guage and is connected to one end of the "limiting coil" which is connected in series with the "operating coil" and then to ground. If you applied 6 volts to this arrangement the current flows through both coils and then to ground, but the guage would read "full" since the operating coil has more windings than the limiting coil. Now the sender, which is nothing more than a 0 - 30 ohm variable resistor is connected at the juncion of the 2 coils. As the tank level goes down, the resistance coming from the sender drops (gets closer to 0 ohms. This causes more current to flow through the limiting coil and less current through the operating coil, and the needle moves towards empty.
The differential windings give the guage accurate readings despite the voltage fluctuations in the system, in fact, I've heard you can run a 6V guage on 12V with no problems at all. But I would think the resistor is a good thing just to keep the current within design specs.
Hope this helps. | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | From a few years ago: Long Gas Gauge thread
| | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | OlBlueit seems to me that I need to know if the gas gauge is in reality a voltmeter or an ammeter. The gas gauge is what's called a "balancing coil" meter. There are two electromagnets, one with a constant-strength magnet, and another with variable magnetic strength. The position of the needle depends on the strength of the magnet controlled by the tank unit. The resistor is inserted in series with the constant-strength magnet, and the voltage to the sending unit is also reduced by this resistor. Basically, you're limiting the current available to the balancing coil and the sending unit, making both of them operate on 6 volts, not 12. Jerry
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Although the resistance values aren't the same for a Stovebolt, THIS shows the basic principle. | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | The tank unit is a variable resistor,it allows current to flow thru the dash unit based on the resistance it is at determined by the float. Put your resistor in series AHEAD of the dash unit. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have used this relatively inexpensive 12v to 6v fuel gauge resister for over 12 years with no problems. You attach the ring end to the "power-in" post of the fuel gauge (not to the sender post). The power-input line is attached to the other end of the reducer (the end with the nut and bolt). | | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | Thanks to all who responded to my "is resistance needed" to convert the 6volt gas gauge to a 12volt gauge. By drawing out the circuit as described by Waldo53 it made sense. For awhile I thought I would put resistor in parallel with the gauge, this would have sent too much current to the gas tank sender. I would have sent my 53 to, you know where!!! Now I know to put my 30ohm resistor ahead of my gauge and all is well..One of these days I'll include a picture, after two years of parts everywhere its starting to look like a truck again. Again thanks for all the help. | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | So, that explains som of my gas gauge situation! I have a 12v system truck.
I got a new sender at the auto parts store, but it took all day to make it work even just a little bit. I got the gauge to move but it doesnt go full scale. And I had to insulate the gauge unit itself from the dash. I thought something might be not quite right.
So, if I get a resistor, will it work? Should I remove my insulation and let the gauge be grounded to the dash? How do I know which screw terminal connects to power and which one connects to the sender?
Now I'll need to get all upside down under there again.... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Scot, you sender must match the gauge. If it is a stock Chevy gauge you need a 0-30 ohm sender. | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | is that something special? I just got a sender from the auto parts store? Or should I get a specific 0-30 sender and a resistor, too? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | not "special", just that the early gauges were 30 ohms, later are 90 ohms, the later ones will never work with the earlier gauge, so yes, you need a correct 30 ohm sender for your series and the resistor, check your shop manual wiring diagram for correct connections
Bill | | |
