2 members (ronsway, 1 invisible),
115
Mod | | | Forums66 Topics128,172 Posts1,057,035 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | Hello all,
I will post my pics and greetings, too, but this just happened today.
I have a 48 chev 3100 1/2 ton, with a 1960 235 6 cyl and a floor shift four speed.
I've just had the truck for a couple of months, and just recently discovered this forum.
On a few recent occaisions, I've noticed a rumbly gravel sound in third gear, just when shifting into third.
Today the sound changed to big rumbly sounds in second and third, but then 4th gear sounds and feels just fine.
So, I don't think its the U-joints, but I am feeling like it's transmission.
Will I be learning trans rebuilding soon?
Or should I swap in another trans?
Or is there anything else I should look at or check before tearing into it?
thanks,
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Fourth is direct so no power is transmitted through gears or other shafts. Because you have no noise in 4th but do in 2nd and 3rd I suspect you've got a gear or counter shaft problem. These transmissions aren't hard to find I'd advertise in the swap meet for a replacement and just swap.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2005 Posts: 98 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 98 | is there oil in the tranny?
50 chevy 3100
| | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | I'll check for oil. the PO said he changed it. I'll look for a used one to swap in, too. | | | | | Joined: Feb 2010 Posts: 45 New Guy | | New Guy Joined: Feb 2010 Posts: 45 | Crack that thing open chance is that you will see the problem right away and can probably repair it yourself,Then you will know exactly what you have in your trans. JMO
Thanks | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Novak sells a very nice rebuild kit for that transmission. picture | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | The rebuilt kit looks like fun. but will I need special tools like pullers, etc? I have wrenches and sockets, like the usual stuff.
Or, what if it is just low on oil? the PO said he changed the oil, but what if he didn't put enough in. How and where do i check the oil level? Or are the bearings ruined if I am hearing big noises?
And I need to positively identify this transmission before ordering a rebuild kit. I am not sure if it is the original. Are there numbers or marks for identification?
thanks all for your help,
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | If you go to the NOVAK site I believe you will find all the info you need to ID your transmission. From what I understand these are very easy to work on but not being a mechanic I had mine rebuilt by someone who does such things... it wasn't expensive. There is a section of the REPAIR MANUAL that covers this if you want to tackle it. Good luck. | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | thanks Woody, I'll check the Novak site | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | I clicked the repair manual link, and i already Have that book.
It has pictures of how it all comes apart with gear puller tools, etc.
the Novak site says it's simple to rebuild, and all that is needed is a small arbor press, snap ring pliers, and a bearing puller.
I have snap ring pliers!
Maybe this is more than I want to get into.
Can I do this? Or should I take it out and get someone else to do the rebuild?
| | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | I should just check the oil level first. Is there a fill plug up high to check how full it is? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes Scot, there's a plug in the side that the oil should be up to, but if it's that noisey it needs to be opened up and inspected, so you should quit waffling and pull it out and see what condition it's in, the answer as to 'what next' will reveal itself
Bill | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | ok, you're right. sometimes I just need to get slapped around a little.. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Getting that monster out of there isn't going to be easy, it weighs a ton! Here's a PICTURE of a contraption I made to deal with the mine. It's pretty simple with a boat hoist thingie to provide the muscle. The only mistake I made was the 2x4 that you see placed front to back should run side to side to allow the movement you'll need to get it away from the engine. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Can I do this? Or should I take it out and get someone else to do the rebuild? Ask around and see what it would cost to have it done. I think my guy charged me $100, but I delivered it and picked it up. Any good mechanic should be able to knock it out in a couple hours.
| | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | I like your puller idea. I can make something like that. And I will check around locally and see about help to rebuild. | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | I got the floor out today, and yes, it is an SM420.
The only bolt that looked like an oil fill hole was on the passenger side about half way up and angled slightly to the rear. There was plenty of new clean oil in there up to that bolt. It was dripping out when I loosened it. I guess the problem was not lack of oil.
So, now what's next?
Should I take the top off and look in there while it's still in the truck?
Or take it out? If taking it out, how many bolts attach the trans to the bell housing? I see two at the top, and maybe one other on the driver side lower, but any more?
I noticed in another post to make guide pins with long bolts replacing the two top bolts for removal and installation.
How long should those bolts be? I can go get some before attempting this removal.
Should I drain the oil first before removal? So it might be less messy?
| | | | | Joined: Feb 2009 Posts: 49 New Guy | | New Guy Joined: Feb 2009 Posts: 49 | Most likely at that year, you have four bolts in a square hooking it up to the bellhousing. It may have metal shavings running around in the oil, or ground-out synchros or gears? | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | There should be a cover bolted to the left side of the box which I believe is where the power take-off would be if so equipped. Remove this and look inside to see if you can see anything. If you can get your finger into the bottom of the case you can poke around for loose bits of metal.
Regardless, your trans is going to have to come out to be repaired. It's supposed to turn smooth and free, anything else is bad news. Transmissions have this bad habit of not fixing themselves. | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | The two bottom mounting bolts are coming through the bellhousing from the front. there is a big bump part on the trans on the passenger side and no bolt head. Do I have a special overdrive trans?
I'm gonna go take out those two bolts. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Do I have a special overdrive trans? Not likely. A few quick pictures would help.
