0 members (), 122 guests, and 2 robots.
Topics128,131
Posts1,056,727
Members48,454
Hey guys,
I need signal lights on my 41 but am hoping to avoid having to install the big round ones on the forward fenders.
I had a thought......would it be possible to us the forward parking lights as signal lights?
Something like how the rear park/brake lights are signal lights?
I was thinking they maybe dim but I could always put a LED in it??????
Has anyone ever seen this or have any thoughts on it?
Yes, it is definitely possible. In the tech tips, look up the signal stat system. Could do LED's, that's true.
1959 Chevrolet 3100 Stepside Apache
"Ignorance is bliss. Here's a history book."
I did it with my '40. Need to change out the bulb sockets to the double contact style, then use the two filament bulb. Took a little bit of modification but works fine. My system is 12v., and I rewired the truck with a Painless kit. I know the '41/46 are different configuration but should still work. Other options would be using LED's, or switch headlights to the style with integral turn signals built in.
1940 Chevy KC 1/2-Ton
Thanks guys!
