0 members (),
256
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | Hey guys, I need signal lights on my 41 but am hoping to avoid having to install the big round ones on the forward fenders.
I had a thought......would it be possible to us the forward parking lights as signal lights?
Something like how the rear park/brake lights are signal lights?
I was thinking they maybe dim but I could always put a LED in it??????
Has anyone ever seen this or have any thoughts on it?
Thanks | | | | | Joined: Feb 2009 Posts: 49 New Guy | | New Guy Joined: Feb 2009 Posts: 49 | Yes, it is definitely possible. In the tech tips, look up the signal stat system. Could do LED's, that's true. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I did it with my '40. Need to change out the bulb sockets to the double contact style, then use the two filament bulb. Took a little bit of modification but works fine. My system is 12v., and I rewired the truck with a Painless kit. I know the '41/46 are different configuration but should still work. Other options would be using LED's, or switch headlights to the style with integral turn signals built in. | | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | | | |
