6 members (Otto Skorzeny, 59 fleet, Peggy M, Hotrod Lincoln, Cletus1950, tclederman), 159 guests, and 13 robots.
Topics128,106
Posts1,056,217
Members48,436
#644820 05/09/2010 4:45 PM
I dismantled (partially) the speedometer on my 1939 Chevy truck to replace the needle that had fallen off. The face has quite a bit of rust, but I can still read the numbers pretty well. I'd like to clean the rust off if possible, does anyone have any ideas? And, is there a way to test it before putting it back in the dash? My thought was to hook the cable back to it and use the drill to see if the number turn.
Angie
If you can't get the Faceplate cleaned up, you can purchase reproduction from Jim Carter Truck Parts, among others.
On the drill idea, must run drill very slowly to avoid damage to gears in odometer
1940 Chevy KC 1/2-Ton
Ex Hall Monitor
Ex Hall Monitor
If it were me I'd send it to a professional speedo rebuilder.
Well, I did take it apart and cleaned it. I carefully attached the drill to the end of the cable and watched the numbers turn.
I decided that I like the patina of a somewhat rusty gage. Here's some recent photos.
www.flickr.com/photos/angji/
Angie
