0 members (), 68 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#64509 08/18/2006 5:10 PM
im sure this topic has been covered but i cant find it, do you have to pull the bellhouseing with the motor or can you leave it bolted in the truck, it's a 51, with a 216 and 3 speed tranny, thanks,,, ron :rolleyes:
#64510 08/18/2006 5:20 PM
It's a lot easier to remove it with the engine because you must remove the pressure plate, clutch disc and flywheel to get to two of the bolts holding it to the engine. I wouldn't want to be under the truck separating the engine and belhousing; I'd be afraid that the engine could land on me when they separated.
#64511 08/18/2006 5:30 PM
I agree pull them together it will be much easier.
Ed
#64512 08/18/2006 5:32 PM
thanks for the help,,, ron
