2 members (ndkid275, Phak1),
58
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 54 | Anybody know the torque setting for the bed to frame bolts. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I don't think there is any torque specs for things like bed bolts, torque specs are usually reserved for things that need even pressure over a larger area to keep things held down evenly like a cylinder head.
Just use good judgement and get them tight. A little Loctite wouldn't hurt if you are concerned with them backing off. | | | | | Joined: Dec 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 164 | Wow Czechman, (light bulb lights up here)
I was going to get some castle nuts myself and drill a hole in one of the castles for a coter pin so they wouldn't back off, not an easy project I was dreading. The loctite never came to mind. I am glad I read these posting everyonce in a while. Loctite will do just a good a job and be much easier. Plus I think I have some in the bottom drawer of the tool box. Thanks again for the tip!
John | | |
