9 members (cmayna, Nick in Manitou, Hanks custodian, RdsLessTaken, homer52, Gdads51, mick53, kurbside bolter, 1 invisible),
79
Mod | | | Forums66 Topics128,264 Posts1,058,355 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Is there a special way to install the fender welt on the back fenders of a 57 3100?
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | I tried....and gave up....looks fine without.....My 2Cents.... | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Jim Carter's catalog indicates that rear fender-welt was not originally used on rear fenders (welting was also not used on Advance-Design rear fenders). Nonetheless, here is a Tech Article from ClassicTruckShop.com Some people have reported that they have cut off the bead and use the remaining strip and/or use a strip of heavy roofing paper/sheet (attached the fender with seal-adhesive). | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Not sure of flange detail on your '57 fenders. On my '40, I used weatherstrip adhesive to hold the welt flange in place before bolting up to body. | | | | | Joined: Dec 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 164 | My Rear Fender Welting Job Click Here I used fender welting on the rear fenders before I read threads on here that none was used on AD trucks from the factory. I cut the welting on angles at the various points where it makes a bend around the fender. I bought a magnet set and a clip set from Harbor Freight for around 15 bucks I think it was. I pre staged the welting and made any trims and cuts to make sure it laid flat on a dry run. I used Super Weather Strip adhesive on the leading edge of the fender and the opposite edge of the welting to create a dual bonding fit. You will have about 4 or 5 minutes to make adjustments to the placement once you start. Do as much work before you start to make it a smooth install as possible. I currently have to get some super weather strip remover to clean up small smudges on the front side of the fender, but all in all I think the look actually came out pretty good considering it never had it originally. John | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | I installed it on both My rear fenders...also My rear fenders had welting on them when I removed them...Its only common sense to install it as You have a metal fender mounting to a metal box with the potential of water, mud, and debris entering and lying dormant, causing a rust problem too soon...To install the welting I cut "V" shaped cuts the entire length of the welting which allows all the bends necessary to install...when installed, the round bead will keep the debris away from the problem area. Bill B. | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi Bill, I hear that is the way to go. How large of a V would you cut out for the bolts? Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Here is a photo of the V-cuts shown at the link I posted above. | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | tc, Great work...do I really have to use the adhesive? I just got the truck back from the paint shop and they left the rear fenders loose and I really dont want to take the fenders off. Can I just cut the V's in the welt and install?
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes you can skip the glue John, only useful to tack the welt on the fender before assembly
Bill | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Got the welt in. It was very easy...ugly cutting job but heck I will not see it. I left fenders loose in order to get the stepsides on. then will tighten down the fender bolts.
Thank you for the help! 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | On a 57 stepside, how far would the welt come down on the rear fender? I was not thinking and cut the welt at the front of the fender right where the seam of the stepside step meets the side panel. I hope that made sense. I will post a photo soon. 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | |
