1 members (Ponchogl),
108
Mod | | | Forums66 Topics128,281 Posts1,058,466 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 30 Shop Shark | | Shop Shark Joined: May 2010 Posts: 30 | Hello, friends. I have a '54 CarryAll with bad driver & passenger doors (w/vents); can I swap the internal works in these two, vents etc. and put them into two great '52 doors (w/o vents)? Anyone ever done this on a 'Burb or Pickup? Want to know if it'll work. Thanks for any input. I love my CarryAll. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes, I've done it; and, Yes, it works.
Minor detail - the colors/finishes of window-regulator knobs were different.
| | | | | Joined: May 2010 Posts: 30 Shop Shark | | Shop Shark Joined: May 2010 Posts: 30 | The window glass and mechanisms, and the vent window assembly will fit in the '52 doors properly? Thanks for your response. I'm impressed! | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | There is no difference between a '52 and a '54 door. '51 doors are unique and '47 to '50 doors are a third design.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There is a small difference in '52 and '54 doors but it's not in the windows. It is the way the trim panels and access panels are attached. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Charlie,
The 54/55 trim panels attach with push-buttons, rather than screws. 54CarryAll was asking about "internal works" but I think he could use the push buttons for the 54 trim panels in the 52 door, after drilling out the screw holes?
However, I know there is also a different on the lower-hinge access panel but I do not know what the difference is - I had thought it was the screw diameter (and dimple-size in the hole covers)?
| | | | | Joined: May 2010 Posts: 30 Shop Shark | | Shop Shark Joined: May 2010 Posts: 30 | Now I'm not sure if my spare doors are '52 or '51 . . . so I need you guys to tell me if '54 vent window and door window mechanism will also fit inside the steel shell of a '51 door? Sorry. I'm very new -- and inexperienced about the AD trucks, though I drove one for the Chevy dealership I washed cars and ran errands for in the 60s. Thanks, guys. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Does your 51/52 door have a turn-down handle on the outside (as in 51) or a push-button outside door handle (as in 52 and later)?
The answer to this question will determine the type of door latch/catch and control mechanism.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Tim is right on the panel attachment difference. The access cover difference is the earlier doors have nutplates and the '54 doors use sheet metal screws. No one will notice. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Can I assume '55 1st doors have the same access attachment as '54 doors? I don't think I've noticed this difference before....
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2010 Posts: 30 Shop Shark | | Shop Shark Joined: May 2010 Posts: 30 | Turn down handles on both older doors. Thank you. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If the doors with turn down handles have wing windows they are '51 doors. Otherwise they are '50 or earlier.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2010 Posts: 30 Shop Shark | | Shop Shark Joined: May 2010 Posts: 30 | These doors have no vent windows but have stainless outside window trim and stainless trim around them on the inside window panel . . . will '54 vents and window mechanisms fit in these ventless doors, even if they are '47-'50 doors? They are so much better than my '54 CarryAll doors that I might even use them as is. Thanks for all your help, gentlemen. I'm learning so much from the Forum Section. --Al Lewis | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The inside trim for the earlier doors has attaching screws where you wing window will fit so you'll have some open screw holes and will have to drill new holes to attach the trim. Also it will need to have a notch cut in it where the wing latch is.
You should do a search of the Doors forum. | | | | | Joined: May 2010 Posts: 30 Shop Shark | | Shop Shark Joined: May 2010 Posts: 30 | Thanks. I'll do that. I appreciate the advice. | | |
