2 members (Ponchogl, Hush),
67
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64448 08/17/2006 2:51 AM | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | I have a chevy 3200 stepside that needs a new rear end. I went to the local junk yard and found one that is 1" wider. The rims I plan on putting on it are crager 15x8's. Does anybody think the one inch wider rear end with these rims will rub?
kevin | | |
#64449 08/17/2006 2:59 AM | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | I" wider is only 1/2" per side, so I doubt it.I used a 76 olds 442 differential without a problem.I think the only problems may arise with what the offset on your rims may be.I'm glad I switched to an open drive line, I also used a 57 Chev passenger car driveshaft as well as a 77 El Camino V8 and a 73 El Camino Transmition .I didn't do too much fabricating too make everything slide into place. Lothar | | |
#64450 08/17/2006 3:00 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | kind of depends on the back spacing of the rims, and the tire going on them... a 325 series tire will come off that rim a little farther than a 255 series tire. 1 inch wider, that's only 1/2 inch on either side. there's a lot of room under those fenders. | | |
#64451 08/18/2006 12:08 PM | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | thank you both for your input
kevin | | |
#64452 09/18/2006 8:02 PM | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Kevin,
If you have a '56 Apache, then you need to measure the outside-to-outside width with the tires/wheels mounted. If that dimension is over 73 inches, then you may be better off obtaining rims with a 1 inch positive offset (Moves wheel toward centerline - They're all over the place). That's what I had to do BUT mine's a Fleetside. | | |
