0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 48 | heres my question, Im putting in a 65 292 with saginaw 4 speed and open driveline, I was told by several sources to get a cross member from a 54 so all will bolt up,, the 54 cross member is like 3 inches longer than the original,, am I missing something was I suppose to cut it up to fit,, looking for input,, | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | don't mean to ask a dumb question, but when you say crossmember are you talking about the whole front end? the motor mount towers bolt to front end crossmember at bottom and frame at top. the 292 motor mount is 2" foward than all the other sixes, so i doubt you will have a hole there in the frame for the 292 mount on the pass side. | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | They're probably talking about the crossmember under the bellhousing. The mounts are at a different angle on the bellhousing that comes with the 292, and the later model crossmember will match up without modifying the crosssmember. Don't know about front mounts- - - -you'll probably have to fabricate your own, IMHO. Jerry
| | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | use a 54 bellhousing x member a 55 chevy truck v8 bellhousings and mounts and you need to make a front motor mount oe the sides buffulo in washington makes them he is on the inliners site, i have done this conversion several times it sure beats using a 235 | | | | | Joined: Sep 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 48 | thanks for the info,, I am trying to change the Xmember under the bell housing,, I have front mounts,, i had gotten the cross member from tom meyers in OKlahoma but it appears he sent me the wrong one,, the inner measurement on my 53 3100 is 30.5 inches,, the xmember I got was 33 inches could be from a bigger truck,, soo Im trying to figure out what i needed to do,,, | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | It sounds like you may have gotten an 55.2 x-member from Tom. The TF truck frames are 34 inchs wide (if I remember correctly). The mounting surfaces of the TF X-member will be parellel with each other and the AD X-member is angled, as I am sure you know. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i bet Mr. Meyers will swap it out for you if has has another one, he has done it for me in the past. i just sent it back after i called him. | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | | | |
