8 members (dt235sd, Lonnie, Wickedbass, Gabes-trucks, Ponchogl, Otto Skorzeny, 2 invisible),
193
Mod | | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 3 New Guy | | New Guy Joined: Mar 2010 Posts: 3 | will a 1939 chevy truck grill fit a 1940 chevy suburban
viejitos de okla
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I believe there are some subtle differences between 39 and 40 chevy grills, but I am 90% certain it will work. You might have to use the 1939 top piece too. I am only speculating.
My advise to you is to forget about the grill and sell the truck to me. Obviously nobody will want a 1940 suburban with a 39 grill, so you will be a head of the game if you just give me the truck.
All kidding aside... Welcome to the Stovebolt page, and good luck with your truck. | | | | | Joined: Apr 2006 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 62 | gwater15. The difference between the '39 and '40 is as follows; The '39 has a narrow upper bar and 16 lower cross bars. The '40 has a wider upper bar and 15 lower bars. I believe these are the correct numbers but at least the '40 has one less bar than the '39. The lower bars are the same ones on both years. Also the '40 has parking lights on the top of the front fenders and has the '41 to '46 instrument panel.Hope this helps. ps. I have a 1939 Chev Suburban myself. Stan Norrish | | | | | Joined: May 2010 Posts: 4 New Guy | | New Guy Joined: May 2010 Posts: 4 | Could anyone help me find the exact location to mount my restored parking lights on the fiberglass fenders of my 1940 chevy pickup? Unfortunately I don't have access to a steel fender to make a template or take measurements. Thank you | | |
