| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | Hi, well 59 is on track but now i have to figure out how to mount new swing brake pedals and get around the stock steering wheel/dash support anyone know a good how to link for this i really could use the advice thanks
1937 1/2 ton
| | | | | Joined: Nov 2009 Posts: 41 New Guy | | New Guy Joined: Nov 2009 Posts: 41 | While I can't tell you how to find a "ready to bolt in" set up,there is an article on Classic Truck Shop called Swing pedal brake & tilt column. They used a newer column, but the fabrication may give you some ideas. I used a swing pedal out of a ford granada/mustang on my 39 Pontiac. It is a neat piece to start with. It has a small booster. I have also used a swing pedal set up out of a mid 80's firebird/camaro. This works best if using a newer column out of the same fb/camaro. Bottom line, you will probably have to fab up someting to bolt to the column mounting holes and weld it to the swing pedal assembly bracket. I have had to heat and bend the pedal arm to curve it around the column also. good luck. | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I used one from a Chevy Sprint of all things. It mounts to the firewall, and has a small booster. I had to elongate the mounting holes in a full size truck master cylinder to get enough fluid transfer to the brakes, but it was nothing a "virginia milling machine" couldn't handle!
I also used an assembly from a F**d Bronco II although the pedal assembly bracket is aluminum and so can't be welded to under-dash bracing.
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
