6 members (Oswald, fonz8261, baldeagle, Hotrod Lincoln, squatchie86, 1 invisible), 81 guests, and 3 robots.
Topics128,014
Posts1,055,333
Members48,419
#64441 08/17/2006 1:36 AM
Posted here one other time about the Zenith carb on my 52 GMC and someone said why don't I just get a new one. I want to but can't seem to find a supplier with one. I even emailed Zenith and they gave me a couple of replacement carb numbers. I'm not too much into having to have the original one but would like a NEW carb that will fit and work well in my truck.
Any suggestions?
Jim
#64442 08/17/2006 2:09 AM
carter, rochester, holley... The ones they use for the chebbys should work on your jimmy. You could probably get some type of adapter to run a 2bbl on the stock manifold. Do you have a 228, 248, 270 or 302.
I ran a 4bbl holley 390 on my 270 , new intake of course. It was a pretty staight forward swap. It gave me much better throttle responce. I didn't benefit from increased economy... foot got much heavier! Everything else was stock, and the engine had 250,000 miles when I installed it. It made it to 272,000 before I pulled it to overhaul. It still fired right up, but My rear main seal was gone and I was losing heaps of oil. I started feeling bad for the fish!
#64443 08/17/2006 6:07 AM
Seems like someone posted a source for the new replacements from Zenith on the OldGMC site awhile back. Might try a search there.
#64444 08/17/2006 3:12 PM
46 Burb I have a NOS Zenith carb to fit GMC, need to know the distance between the mounting studs on the intake, mine are 2 3/4", also what size motor do you have. 1-918-542-3871 or E-mail [email protected]
#64445 08/17/2006 6:31 PM
Carburetion specialist
To determine WHICH carburetor was used on which G.M.C. engine, try here:
http://www.thecarburetorshop.com/TRGMC.htm
Jon.
The Carburetor Shop
