2 members (Peggy M, crenwelge),
173
Mod | | | Forums66 Topics128,077 Posts1,056,015 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Hi there,
I am very new to working on trucks and am in the process of restoring a 1954 Chevy 3100. The 12 volt conversion seems to have been done and my battery is good, however when I turn the ignition and push down on the foot starter nothing happens. My horn works but no lights or blinkers.
Any thoughts out there from the experts? I am considering "re-converting" everything myself to make sure it is done right.
thanks,
Carlos | | | | | Joined: Mar 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 46 | Hey Carlos,
Don't start over. Do you still have the original, foot-activated, starter? Send me a PM - I'm right next door in Santa Clara | | | | | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | moto hack maybe you can help me also I'm in monterey and trying to get top dead cente to install the stovebolt mini hei and holley 2 barrel carb with fenton duals on my 54... same problem wiring looks good but has a few cracks in the wiring nothing major but I need to change afew things like no ballast resistor when I add the new hei and add a electric choke wire - question is do I need to rewire or just fix what needs to be fixed?already converted to 12 volt... as well as finding top dead center to get it fired up. is there an easy way on the 235 to find TDC? thanks for any help you can give.... | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | The simplest, most effective way to find TDC is to remove the valve cover and watch the valves as they operate. The piston will come to the top of its stroke twice in a 4-stroke cycle, once on the compression stroke with both valves closed, which is when the spark needs to happen, and again one turn of the crankshaft later, at the top of the exhaust stroke. Both valves will be slightly open then, with the exhaust valve closing and the intake beginning to open.
With all the spark plugs removed you should be able to turn the engine over by hand by turning the fan. Turn the engine clockwise from the front until the last valve near the firewall (#6 exhaust) begins to open. Continue turning until it starts closing and the one next to it (#6 intake) starts to open. At that point, both #1 and #6 pistons will be at TDC, with the #1 cylinder ready to fire the spark plug. The timing ball should be visible through the hole above the starter, and it should be very nearly aligned with the pointer in that hole. Install the distributor with the rotor pointed toward the #1 spark plug wire in the distributor cap, and arrange the firing order clockwise to be 1-5-3-6-2-4. Crank up and go! Jerry
| | | | | Joined: Mar 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 46 | Hi Marlon,
I sent you an email via the address in your profile. For me, electrical issues are easy. I spent over 20 years as an engineer on Airborne Electronic Warfare systems. I'd see what you've done with your truck. | | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | I hooked up my fully-charged up battery, tested it by honking the horn (which worked). I turned the ignition, stepped on the foot-starter and........nothing! Whatever happened, it drained my battery or shorted it out or something. My horn wouldn't work after that.
Does this sound like a wiring, ignition, or battery cable problem or something else?
Carlos | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Sounds like a cable problem to me. | | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Thanks for the tip, I was considering changing out the positive cables. I have already changed out the negative ones. | | | | | Joined: Jan 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 55 | Carlos, My 6v was acting just as you describe - that is until I swapped out all cables. | | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | The battery cables or the entire harness?! | | | | | Joined: Jan 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 55 | Carlos - sorry I haven't checked in. 3 battery cables - 1 pos + 2 ground | | |
