0 members (),
256
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | I ordered clutch kit and received one manufacture by Autocon, CA and made in Korea. This pressure plate has only 8 bolt holes and my flywheel has 10 bolt holes. And one more thing how do I know if engine was 3.5 liters or 3.9 liters.
I swapped my engine to 235 from 58 apache and still using original bellhousing, clutch kit.
Any suggesstions and links so I know where to buy the correct one pleas
Ganesh | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | A little red-neck math; If a 302 ford is a 5.0 liter that means that every liter is 60.4 C.I. So 3.5 x 60.4 = 211.4 (probably a 216) 3.9 x 60.4 = 235.56 (probably a 235) | | | | | Joined: Mar 2005 Posts: 98 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 98 | 61 cubic inches per liter. ford 302 is really 4.95 liters
50 chevy 3100
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I think this is the real problem. I would suggest a Hays, I'm running one in mine and am very pleased with it. Plus, it's USA manufactured.
Bill Burmeister | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | That was good calculation and so I had 3.5 L engine. Glad to know that
Ganesh | | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Or, use a conversion factor of 16.4 CC per cubic inch. Jerry
