| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | My truck came with a 2 wiper setup but somewhere along the line lost the passenger wiper. The driver side motor was loose inside the headliner. Is it attached to the cab ceiling by the wiper arm? What all is needed to re-attach this? I'm not concerned about the vacuum at this point. Do the new wiper arms come with attaching hardware? | | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | To install the motor first place the ~1" long adapter bushing over the end of the shaft. Next insert the shaft through the hole in the cab. Place the rubber seal over the protruding shaft followed by the specially shaped washer which conforms to the cab profile. Finally install the chromium plated nut on the end of the shaft to hold everything in place. At this point the wiper arm can be installed.
Those attaching parts are available but do not come with the wiper arms. | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | I'm missing everything on the outside. I see where to get the seal and what I assume is the washer but called a chrome bezel. The nut would be found at the local hardware store? Are these wiper arms all special order or will something at the store work? | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | You could try and put an ad in truck parts wanted I've gottin some parts from that .
Pete | | |
