0 members (),
134
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 2 Junior Member | | Junior Member Joined: Sep 2001 Posts: 2 | I'm rebuilding a 1935 chevy 216. It has new everything! I just put it together, cranked the oil pump to get oil to the lifters, and out comes oil from the rear main. (I had NAPA do the machining to crank and install bearings. He said no main bearing seal was used in these old engines). Well---I have oil comming out of the rear main. Any clues as to what went wrong?? I need help!! Thanks, Wayne | | | | | Joined: Oct 2001 Posts: 36 Member | | Member Joined: Oct 2001 Posts: 36 | HE SAID WHAT!!! Of course there's a rear main seal! The original was a rope seal although there's a neoprene seal available. I've had no experience with the neoprene seal--installing either is difficult but not impossible with the engine installed. Getting the top half out and in is the problem--of course, you don't have to remove one!! Have you considered a different machine shop?? :rolleyes: | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Unless the '35 is different in a big way from the 216 in my '52, then it's gotta have a seal back there. What's gonna keep the oil from coming out?
If you have a gasket kit, check and see if you can find two pieces of wick (they call it "rope") about the size of a pencil. One piece fits in a groove in the top, up in the engine block, and the other is for the main bearing cap.
It still might leak a tiny bit with the rope seal, but it certainly shouldn't gush out. I'd say a drop or two every time you shut her down is pretty normal. Look for an old timer who's an expert with 216 if you want ZERO leak with the rope seal, because it takes some skill to make it totally leakproof.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Well gee, if oil is gushing out, I am pretty certain something should be there to prevent it. Langdon's stovebolt company sells the original rope seals (the kind with asbestos). He can also advise you on your problem (though I think the only problem is the guy giving you advice). http://www.stoveboltengineco.com/ | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Hold on there fellows. If it's a 35 it's a 206 and I don't believe they had seals. Just an oil slinger on the crank. | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Forgot to add, also the 37-39 216's used the same setup I believe. | | | | | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | thats right no rear main seal up to 39 theres a link where a machine shop offers a full circle rear main seal for this engine. If it ever needs replaced the flywheel can be simply removed and a new full circle seal replaced without doing anything else. do not have to remove pan or anything. If you send your block to him he will machine and offer this seal for all 216 and 235's sounds like a good deal to me if a person is doing a rebuild anyway ???? Mike | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | So they just intended for those old engines to spew oil straight from the factory? I don't doubt it, but seems awfully strange.
#4997 02/28/2002 10:48 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Even though oil is comming out by spinning the oil pump does not mean it will when it is running. That engine(206ci) uses a oil slinger so when running it should not. If the mains are set to loose you will also get to much oil in this area.
See the USA in your vintage Chevrolet! My Blog | | |
#4998 02/28/2002 11:22 PM | Joined: Sep 2001 Posts: 2 Junior Member | | Junior Member Joined: Sep 2001 Posts: 2 | Holly cow!! Thanks everybody for the response's. Maybe it is a 206, I hadn't heard of one! (Just getting into this rebuilding stuff). On the title it has the engine number, #T1835085. Also this engine came out of a 1938 1 1/2 ton truck. The title is for a 35. I called the NAPA machine shop and he said bring it in and he will look into it.Not sure what to do now! Guess I could start it and see if it leaks then. Please keep in touch and let me know if you have any other ideas! Thanks again!!! | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 216s were first used in 1937, so your 38 (if original engine) is a 216. Check for the casting date on the block, it's behind where the starter would hide. Also Chev did not start using a rear seal until 1940.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2010 Posts: 1 New Guy | | New Guy Joined: May 2010 Posts: 1 | slim, tell me about the machining process to install a lip seal on a rear main 39 chevy 216 | | |
