| | | Forums66 Topics128,132 Posts1,056,386 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64382 08/15/2006 10:47 AM | Joined: Jul 2005 Posts: 71 Member | | Member Joined: Jul 2005 Posts: 71 | I have a failed diaphram (I think) in a 270 11.5" clutch. It has stiffened up and will only just disengage with a short,heavy action instead of a smooth,light,progressive one. It's not slipping. Is this all typical of diaphram failure?
I have a NOS diaphram; a military workshop manual I have,shows a jig for assembling the pressure plate. How necessary are these? Looking at another old p/plate, it looks as if it could all be done by hand.
Is there any problem with this?
Thanks | | |
#64383 08/19/2006 9:11 PM | Joined: Jul 2005 Posts: 71 Member | | Member Joined: Jul 2005 Posts: 71 | No-one had any experience with this?
:confused:
Thanks | | |
#64384 08/19/2006 9:57 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Are the fingers even all the way around? Sometimes one of the springs in the disc fall out & lodge in the pressure plate or something breaks inside letting one side come out furthure than the other. I don,t think anyone fixes one themselves anymore. You can exhange it for a rebuilt one but most of them know are sold new. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#64385 08/20/2006 9:04 AM | Joined: Jul 2005 Posts: 71 Member | | Member Joined: Jul 2005 Posts: 71 | Thanks Wrenchbender. The fingers are uneven - maybe 1/8" variation but there are no broken parts. The pressure plate that was fitted previously was worse & I replaced it with this one which visually looked good but I guess had been pulled out years ago for the same reason. The only person I've found with first-hand experience of these military clutches failing, is an old farmer who drove one for years carting cattle. He described similar symptoms - gradual stiffening etc & eventually a finger or two breaking. I probably should give it all to a reconditioner; I don't think the 11.5" pressure plates are available over here new.
Thanks again. | | |
