2 members (NJC, Shade Baby), 145 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#643646 05/05/2010 4:36 AM
I am in the middle of a complete frame off restore and I just started the engine for the first time yesterday which was pretty exciting ( 1952 235). The only wiring I have done is the wiring for the coil, distributor, starter, and alternator (converting it to 12v). Well, the engine was running, the alternator was charging, then I went to crank it again to time out the engine and the starter is dead. The battery has full charge and when I send power to the starter, the battery cable just jumps and heats up. What's going on?
1946 2 Ton Flatbed
Good starter to frame ground? Replaced foot starter switch with a side post switch on starter? Rebuilt starter before install? All or any of these can be a culprit.
Drew
DrewP #643710 05/05/2010 1:30 PM
The ground is good, it is a freshly rebuilt starter, and it has a foot starter switch. I realized the gear was still engaged while the engine was running, so it was spinning with the engine for 2 - 3 minutes. Would this have anything to do with it? How do I test the starter?
1946 2 Ton Flatbed
You have probably done some internal damage to the starter by running with the drive engaged that long. The gear is supposed to overrun and prevent the armature from turning, but it's possible the drive locked up and began spinning the armature several times engine speed. That will throw the windings out of the armature and lock it up, as well as creating a dead short. Remove the starter and dismantle and inspect it, or take it to a rebuilder. I'm going to bet it's trashed!
I had the same problem on my 216 engine, battery, starter were good. I noticed that the starter bendix was not engaging the flywheel, turned the flywheel until everything lined up and its worked fine since.
Good Luck
Charlie
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
Charley #643743 05/05/2010 3:49 PM
Yep, the armature is trashed. Open it up and all kinds of copper chunks fell out. Can't believe it. Just got her running too. Any recommendations for rebuild?
1946 2 Ton Flatbed
Rebuilt starter from Classic Parts run $150.00 for a 12v plus $75 core charge. I had mine rebuilt for $85 here in OK City.
1953 5 Window
2006 Chevy Colarado
Charley #643753 05/05/2010 4:21 PM
Thanks. Does anyone know of any other kinds of starters that might fit a 235?
1946 2 Ton Flatbed
Call Todd's Auto Parts, Nashville, Tennessee. 615-254-6264
If they're not bailing out a few feet of flood water right now, they should have an armature, or a complete starter in stock. They specialize in rebuilding old, hard-to-find electrical parts. They're only a couple of blocks from the Cumberland River, so I'm not sure if they got caught by the flood waters or not.
Assuming this is a 52 3100, NAPA lists it for $57.50 + 17.50 core charge.
(#RAY 2449651)
regards,
Leon
Leon #644380 05/07/2010 8:25 PM
I can supply whatever you need for the starter, armature etc. if you have trouble locally. Send me a Private message.
Ken
