Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
5 members (Bill Hanlon, kades51, 49nut, JW51, 3800GUY), 570 guests, and 1 robot.
Topics126,778
Posts1,039,288
Members48,100
Most Online2,175
Jul 21st, 2025
#643696 05/05/2010 12:07 PM
SPL
Offline
I have removed the valve cover on my 235 six cylinder and have found that the oil connector tube centered on the rocker arm shaft is crimped about 80%. The crimp is at the top of the loop where it begins to turn down to the head. Does this need to be replaced or can I live with it? The engine has been running like this but I'm wondering what could possibly happen? I would appreciate anyone's experience on this.
SPL #643705 05/05/2010 1:06 PM
Every one I have seen is crimped at least a little. Maybe someone knows if this was an "adjustment" made at the factory to allow oil flow out the end of the tube but to also increase oil pressure in the block and flow into the rocker arm tubes?
Interesting! The output line from my oil pump is also crimped like this, and I figured someone crimped it on purpose to increase oil pressure. I'll have to check the oil connector on the rocker shaft.
Stove #643731 05/05/2010 3:25 PM
This was to force oil thru the rocker shaft and not shoot out the tube. Kind of a mickey mouse deal but it worked.
SPL #643733 05/05/2010 3:29 PM
That line is simply an overflow tube to vent excess oil from the rocker shaft. Crimping it puts more oil to the rockers and less being dumped back into the crankcase. Leave it "as is" and be happy you've got enough oil flow to make it leak a little! Sometimes the feed pipe from the bottom of the engine gets clogged or restricted, and the rockers get starved for lubrication.
SPL
Offline
Thanks everyone. I guess there's still the plumber in me that says a crimped pipe ain't good.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.066s Queries: 14 (0.048s) Memory: 0.6149 MB (Peak: 0.6657 MB) Data Comp: Zlib Server Time: 2025-09-22 17:40:27 UTC
Valid HTML 5 and Valid CSS
