2 members (Guitplayer, 1 invisible),
174
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 5 New Guy | | New Guy Joined: Dec 2009 Posts: 5 | I have an old 1949 235 babbit engine my 43 chevy 3600, I want to swap out the 49 235 for a GMC 248 bearing full pressure engine. It look identical is it? any problems doing this? Please anyone done this or know of someone who has? Thanks. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Have you looked at the Tech Tip about replacing a 302 for a 216? The 302 block is the same length as a 248 and the 216 block is the same length as the 235. The 248 is a couple inches longer than a 235. Also, keep the 248's pressure plate and clutch assembly (most likely the bolt patterns for attachment to the crankshaft are different). | | | | | Joined: Dec 2009 Posts: 5 New Guy | | New Guy Joined: Dec 2009 Posts: 5 | Thanks I have the bellhousing, clutch and pressure plate setup. Tranny all the same? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You'll probably need the Chevy bell housing for the mounts. It will fit the 248. And your tranny will fit. You'll need to move your radiator forward. | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 |
Back in the day a popular swap was a 270 gmc for a chev 6 you either had to move the rad forward or build a special water pump. Cant remember details on the pump. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | It look identical is it? any problems doing this? Thanks. one the surface they they look the same. gmc blocks are longer as stated. manifolds look the same but wont fit. the flywheels arent interchangeable. bellhousing is the same so you have to make up the two inches in the front plus a new mounting location. like tim said keep the clutch and flywheel assembly. it can and has been done and i looked at doing it until i saw what i needed to do and just replaced it with a post 54-235 that i had rebuilt. with all the work involved to gain 13 cubes wouldnt be enough for me to do it. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | This was and still is a common swap. My main concern with the GMC motor is that they are notorious for having cracked heads. My only GMC had a cracked head as were all the other heads I could find. Also get a Patrick's catalog, has lots of tips and how-to info on these motors. www.patricksantiquecars.comph 520 836-1117 | | |
