5 members (Donf, 1955 1 Series, Gray_Ghost, J Lucas, Forty9), 99 guests, and 3 robots.
Topics128,159
Posts1,056,901
Members48,458
#64348 08/14/2006 4:19 AM
Junior Member
Junior Member
Well the first thing I did when I bought this truck was try to stop the leaks. I disconnected engine and jacked it up in place. Changed the oil pan gaskets and thought I had it licked.
Now this thing is leaking so bad the oil is sweeping down my exhaust pipe. Im getting ready to pull out everything and seal it all. I see one from coming from the fuel pump but there is more to it I'm sure.
Does anyone have any tricks or information on historical areas for the 230 6 cyl that I need to address? I want to have everything in my hands before I start.
O BLUE
Hunting season is about 4 weeks away.
This truck will definetly go on the back burner in 4 weeks.
[email protected]
Riding in the Passing Lane
If its running down the exhaust pipe its probably the valve cover gasket. That is the most common place on these engines. Even if it has a new gasket it can fall out of place when installing the cover. Fix the most obvious leaks & take it to a car wash & clean it all down. Then watch for other leaks. Make shure the PCV system is working. If it doesn,t have a tube running to the air filter it must have a ventilated oil cap.
1972 Chevy c10 Cheyenne Super
Junior Member
Junior Member
Well I yanked everything out. Im going to seal it all right the first time. Repainting engine and transmission. Going to be real clean under the hood now.
shor
Duck hunting season opens next weekend
shor...good luck. I did the same thing that you are talking about a few months back to an engine I got from a fellow bolter. Replaced every gasket I could find on the engine including the rear main. I still got small leaks from time to time.
Daily Driver 63 C-10 LWB Fleetside
You might want to pop off the oil filler cap and see how much blow-by you have. Primary cause is high miles, worn or stuck rings, worn valve guides. If it isn't huffin and puffin with the filler cap off.....and the PVC valve is functioning properly, you're headed in the right direction which replacing gaskets (with neopreme) and sparingly with the sealer.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Great question and great tips and suggestions.
To be precise, the New York Times publishes the leaks, the leaks actually occur in various agencies and organizations. grin :p
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
