| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 22 New Guy | | New Guy Joined: Apr 2010 Posts: 22 | I have put in a replacement headliner in my 54 1/2 ton (2 piece) but messed up the cardboard and it doesn't look as good as I'd like. I want to find some black plastic that will bend and cut easily but will attach in one piece. I figure I can trace around my old one and cut it close to accurate. Any ideas where I can find the material in a 3 x 4 sheet? ... or other options. | | | | | Joined: Mar 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 46 | TAP Plastics sells ABS plastic sheet with a textured finish. Cuts easily with a jigsaw. Edges can be sanded and heat polished (soft flame propane torch - avoid direct flame contact. ABS can be thermo-formed to fit contours.
Grainger and McMaster-Carr also sell sheet stock | | | | | Joined: Feb 2009 Posts: 44 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 44 | try Quietride in California. They have a website. I got my '37 headliner there. It was well made formed plastic. | | | | | Joined: Apr 2010 Posts: 22 New Guy | | New Guy Joined: Apr 2010 Posts: 22 | thanks for the suggestions. I was having a hell of a time finding ANY suitable material from plastics companies, art stores, big box stores, or upholstry shops - at any price - then went to a local craft chain called Michaels. Found a 3x5 roll of black plastic foam for about $7.00. Bought a few rolls and after some experimenting found that gluing two together gives it some stiffness and still shapes with heat gun. | | |
