1 members (stlcardinalsguy),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | Does anyone know what kind of fluid should be used in the arm shocks?
The manual says something about "insulating shock fluid." I have no idea what that might be in today's language. Maybe hydraulic jack fluid?
Gary | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | My father sold the old knee action fluid back in the 50's. When we could no longer get it, we sold the people type A automatic transmission fluid and it seemed to work fine. | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | Crenwelge,
Thanks for the quick response. I will pick up a can on my next trip to town. I just broke into the first shock. It still has fluid, and articulates. Not sure about the next three, but I will soon know. I'll break it down tomorrow, and see how the inside is.
Gary | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hydraulic jack oil also works nice in those shocks. Any farm supply will have larger containers. DG
Denny G Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | Go to motorcycle shop and get oil for motorcycle shocks(front forks). You can customize with different weights. It's all good. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Can this fluid be flushed/changed?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks Squeeze. This is a good manual. Unfortunately, my manual is written around the 54 truck, not much on my 48.
I looked at your attachment and could not find the part on 'simple flushing' of the fluid. I would like to open a drain valve and pump whatever fluid through it to clean it out. I am not sure what to flush through it and what the end fluid should be? Automatic transmission fluid, hydraulic jack fluid, or motorcyle shock fluid? I would like to clean out the interior and fill them with new fluid.
Oh. I have the double action shocks.
Thanks again
