| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64343 08/14/2006 1:03 AM | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I've heard that a T5 shifter in a Camaro has a shorter shift throw than one in a S10. If this is true, could I use a Camaro shifter on my S10 tranny and not have to modify the truck shifter? I'd like to shorten the shift and use a longer shifter handle. | | |
#64344 08/14/2006 2:21 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Maybe, if you have bucket seats. The Camaro tailshaft has the shifter at the back, while the S-10 tailshaft has the shifter at the front, closer to the normal location for a pick-up. From what I've seen, the S-10 shift throw is fairly short anyway. Extending the handle shouldn't be a problem.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#64345 08/14/2006 2:31 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Fortynine5 - I've been working on this myself. The Camero T-5 shifter will not work on the S-10 T-5. You can achieve a shorter throw with the stock shifter by reworking the shifter to have a longer distance between the ball at the bottom of the shifter and the pin location. To do so, you will have to build up the base of the shifter. Tom Langdon has more information on doing this. The other option is to buy a B & M or Hurst short throw shifter. They are on Ebay on a very regular basis. The B & M shifter handle is long enough to work nicely. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#64346 08/14/2006 2:27 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just a thought....the S10 shifter has the heavy bent shaft with the rubber vibration isolator in the S10 stick. I wanted to use the sm420 stick so I salvaged a shift unit out of a Ford application which has the isolator at the base. It doesn't shorten the shift throw but I put it into the S10 base, bolted it back on and bolted my modified sm stick back on and you have an isolated stick, no vibration and not having to guess or R&R the whole unit to get the stick at the correct angle. Check pix in gallery.
The BorgWarner Ford units are about $10. at most salvage yards. | | |
#64347 08/14/2006 4:19 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I used a Hurst short throw t-5 shifter unit I picked up used on E-bay. The Hurst unit, unlike the stock unit and B&M units, just has a flat piece of steel with two threaded holes in it that you bolt a shifter handle to.
I cut off the bottom of my stock 4 speed shifter, welded a piece of 3/8" stock to the bottom of the rod and once the boot is in place over the shifter, it looks stock, except for the fact that it is closer to the seat.
Originally I had an s-10 tranny with a firebird shifter. I don't think the firebird/camaro shifters are any shorter throw than the stock s-10, but they could be. The reason I wanted the camaro/firebird shifter is that it sticks straight up from the shift box while the s-10 has an angle. The firebird shifter mounted right up to the s-10 box, no problem.
The stock s-10, camaro/firebird and aftermarket b&M short throw shifter all have threaded rods coming out of them. When I was going to use one of those and my original shifter rod I planned on welding a threaded nut to the bottom of the original shifter, like the one welded to the bottom of the stock shifter. I found them at Lowe's and NAPA in thier bolt bins.
