7 members (50Chevy3100, Gray_Ghost, Maybellene, 1955 1 Series, baldeagle, Shaffer's1950, Uncles51),
106
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 38 New Guy | | New Guy Joined: Jan 2002 Posts: 38 | Hi all,
I just bought I new repop tailgate. it came in bare metal, I was kind of expecting primer at least.
anyway, here is my question.
I have two areas of concern. the areas where the sheed metal is spot welded together and the area where the sheet metal is rolled to form the top and bottom sections.
1. do you need to worry about getting paint into these areas? 2. how do you do that?
I'm worried about painting the tailgate, and having the area where it's spot welded rusting a bit and running onto paint?
i'm not worried about it rusting out, since it will be kept as a classic, and won't see much driving or rain (unless I get stuck in it)
Am I worrying too much? or is there a simple solution to this problem.
thanks all
"So many trucks, so little time!"
Vehicle list: down to 2 now. 1 - 1967 Chevy 3/4 ton LWB 4x4 2 - do I dare say it??? a 61 Ford Unibody | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I suspended by bed parts from the rafters in the garage for painting. That way you can see where you are as you go.
The paint is about 6 months old and has been stuck out in all kinds of weather. So far, So good.
If your area is prone to rust you are right to worry. I am fortunate to live where it doesn't matter that much, but have lived in areas before where rust is the enemy. | | |
