2 members (GrandpasJimmy, dunfire), 64 guests, and 4 robots.
Topics128,194
Posts1,057,263
Members48,466
is there a place where i could see this ?. i do not currently have a 58 shop manual (one is on the way)...
i found a google link that shows 59 big car 6 cyl wire diagrams , but it doest clearly show what i want (i am haveing trouble starting old 59).
thanks
paul
the 55 manual diagram will cover it, all the same .... bookmark Kieths site, find near everything you need
was 55 the year that the color codeing of the wire was standardized ?
or was it later ?
thanks for the links.
i love the oldmanual site.
I think it was actually earlier the colors were settled ... the colors on the 55 diagram are the same as the 58/9, although on old wiring they're frequently pretty faded except where still wrapped
hard to see some of the detail.
for instance the ampmeter.
the speedo/assembly guage cluster is missing and iam replaceing it ....i am looking at a bunch of wires.
can you tell me where the main grounds are .
the key ignition ground
the dash grounds.
also i cant find the fuse assembly ?
its missing i guess- cause its not under the dash by the parking brake!
thanks for any pointers
paul
do i need fuses ?
i want to check all the grounds and am unsure where to look for them.
thanks
dash grounds are via the mounting of the metal parts to the metal dash, cinch'em down tight .... fuse panels were only installed [on the firewall where you could kick it with your left toe you should see a dotted 'knockout' in the cardboard pad] if there were more than one electric option, like heater, radio, wipers - on the schematic it's called 'accy junction block' or something and is dotted lines - those are available from most vendors and only adviseable if you do have the options, which still could be fused individually with inline fuse holders
the schematic is more readable if you save it to your computer and print it - if you have an image editor you can also save it, rotate it, and enlarge it, but printing it should fill a page same as in the manual, a magnifying glass helps wink
much appreciated. thanks for the info.this truck came with vac wipers, radio delete but it does have a heater.
guess it came from the factory with out a fuse array holder.
smile with my current farmboy web/computer set up i cant seem to enlarge certain images so far..... not giving up though.
thanks again
paul
If you have photo storage on your computer you can transfer the image to there(right click on the image and it will have a "save this picture" link) and then you should be able to enlarge it in your photo album.
Drew
thanks for the suggestion. tryed that. apparently photo wizard is lacking.
eventually it'll be time to get another (hopefully simpler) more versatile tool.
smile
grin
my ebay 58 shop manual came today.
needless to say it is great. found the wireing diagram right away.
every one should have one of these.
