1 members (Danielbolt),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | guys, in my 57 i currently am running a 1980 1/2 ton rear with 5x5 lug pattern. the overall width is 65 inches. that, and the lug pattern has limited me in my wheel width and selection. most of the wheels i like are for 5x4.750 bolt patterns out of a car.
so my question is, what style rear housings are you guys running ? camaro, chevelle, etc ?
i am doing my homework and have a line on a rear form a 70 chevelle that is 62 inches wide, gaining me 1.5 inches on each side, allowing me to use a deeper dish wheel of my choice.
i want to stick with the leaf spring setup.
just curious what you guys are running ?
thanks much.
leonard | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | How ya doing there Leonard. I used to run a Firebird posi in my ol' '59 and you might check Nova's also. For that matter a tri-5 passenger car would work too. What kind of gearing are you looking for? | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | hey waldo... im looking to keep the ratio around what i have now, 2.80. i think i will keep my search for a firebird/camaro housing, or even an s-10. i found an s-10 housing also, but the ratio is 3.42. right now, with my th-350 trans, at 65mph i am at 2200 rpm's, and am afraid the 4.42 ratio will get my rpm's up too much.
thanks for the help.
leonard | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | called american racing wheels directly and found out they will make a rear set of torque thrust II's with the grey painted centers, with my lug pattern and backspace needed, 15x7, 5x5 with 4.5 backspace. standard price of $225.00 each and takes 4-8 weeks to receive. SO, i think i will keep the 1/2 ton 1980 truck rear i have, and just lower it to where i want, then order the wheels when i get the cash. at least that is the plan for now.
leonard | | | | | Joined: May 2008 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 49 | I have just finished a similar rear end swap. I used a 3rd Camaro (1985 model) with a 3.08. It fits great, but you have to cut off all the coil spring mounts and weld in a new spring perch.
Hugh
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks for that info hugh... got any pics ?
leonard | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | Beind the Chevy guy that I am, I hate their rear ends, at least under 3/4 ton. The axles ARE the bearing races, they are retained at the center by c-clips instead of pressed bearings at the ends, and gears are difficult to set up or change. BOP rears fixed the c-clip problem, but the gears still have to be hammered into the case.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | yea, i always liked the ford pumpkins. use to have a hot street car, pinto with 351w, and when i would race it i would swap out the pumpkin that had lower gears.... 2 pumpkins are better than one. LOL.
leonard | | |
