0 members (),
70
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 1 New Guy | | New Guy Joined: May 2010 Posts: 1 | Hello, new here so I don't know in the thousands and thousands of posts I have gone through if someone has come across this problem and fix yet... if so would love the help!! I'm using a 88' Ford R&P for my power steering setup and trying to keep the stock Chevy spindle setup. Now the Chevy tierod ends that bolt into the Chevy spindles are larger than the stock Fords tierods and will not work with the Chevy dropped spindles. Is there a bushing kit or some sort of reducer to press into the hole on the spindle to accept the Ford tierod? or a Chevrolet tierod that will connect to Ford rack and pinion and fit into the Chevrolet spindle hole? The spindles are from a full size Chevy truck 1985 and the entire setup is on a 1950 GMC shortbed 1/2 ton. All that is left for the rolling chassis, is to get this rack and pinion setup to work. Have driven people crazy at auto parts places trying to find the correct setup for the whole thing and thought with the vast knowledge out here, someone may know... Thanks Chris in Las Vegas, NV. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | How about cutting down ford rod, and welding end of Chevy rod to it ? | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | A machine shop can make some sleeves for the holes, if it is just a matter of one being larger than the other. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Search the catalog for ends that fit the rack and have the proper or a larger taper on the other end, then if necessary the holes can be reamed to fit larger ends. | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Use the tie rod ends that fit the steering arms, and drill & tap them for the threads of the Ford inner tie rods. You're not likely to find a tie rod end that will adapt those parts without some modification. DO NOT WELD ON STEERING COMPONENTS! That's deadly dangerous! Jerry
