0 members (),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | I'm in the process of doing a 57 Cameo. We've got a pretty decent tailgate but it is slightly bowed or "stretched" top to bottom. Wanting to get everything as perfect as you can, is there a way to "shrink" that back or get the bow out of it? Thanks, regmudd | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | at least with the plastic cover all you have to do is get the inside lookin good and don't have to worry about the embossed logo!! if the bend includes the end caps, you may be able to just bend it back, if it's only the flat sheet metal panel 'bubbled' in the middle more likely it'll take some heat shrinking .... see this threadBill | | |
